91 camaro v6 3.1l to 350tpi
i will be buying a 1991 camaro rs for 200 dollars it has a 3.1L v6 that i want to swap to a 350 tpi ok first i need to know what i need to do to get the v8 in there and runnting second i want to know what i need to do to get the tpi intake off of a 305 to fit a 350 and i also need to know what what block that is a 4 bolt that it will bolt to i also need to know if the 5 speed in the car will hold the power from the 350 sorry if it seems im asking too much
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It's not asking too many questions, although taking a breath every once in awhile would be nice (you know, using punctuation
), and some of your questions are answered in the V6 to V8 swap sticky in the top section of this forum.
Getting a 305 TPI on a 350 is generally simple enough, because they are basically the same engine externally. What matters is the year of the 305 and year of the 350. '87-up small block Chevys (you know, 305's and 350's) had the center two intake manifold mount bolts at 72 degrees instead of 90 degrees like the rest. Otherwise, a TPI swap is a matter of getting everything associated with the TPI from a donor car (TPI intake hardware, harness, sensors, ECM, hoses, throttle cables, etc.) and installing it all in your car.
4-bolt main 350's typically came in Corvettes and trucks. It generally isn't necessary to pay the extra cost of getting a 4-bolt for a TPI street engine.
The V6 T5 5-speed transmission is not a good choice for a V8 swap. The bellhousing doesn't fit, so you need to get a V8 bellhousing. The input shaft is a different size, so you have to do a "hybrid" clutch. The transmission is weak, so you'll have to baby it in order to get any kind of life out of it.
), and some of your questions are answered in the V6 to V8 swap sticky in the top section of this forum.Getting a 305 TPI on a 350 is generally simple enough, because they are basically the same engine externally. What matters is the year of the 305 and year of the 350. '87-up small block Chevys (you know, 305's and 350's) had the center two intake manifold mount bolts at 72 degrees instead of 90 degrees like the rest. Otherwise, a TPI swap is a matter of getting everything associated with the TPI from a donor car (TPI intake hardware, harness, sensors, ECM, hoses, throttle cables, etc.) and installing it all in your car.
HoosierinWA
Oct 7, 2015 10:15 AM
