replacing a V6 TBI with v8 carb possible ?
Old Aug 22, 2009 | 12:39 AM
ziggy56's Avatar
I have found a good priced 3rd gen camaro with a rod knock in the v6. I have perfectly good V8 in the garage it just needs a ring job. I was wondering if there would be any problems bolting this on to the camaro ? Will the V8 fit the tranny ? and will the tranny run without the computer ? I origionally had the v8 in my chevy truck with a 92 700r4 and no computers whatsoever so I am hesitent on the switch over to this tranny with a computer. I have the motor mounts for the v8 so that is no problem and can get the gas pressure right with the regulator of the line on the truck. just need to know if there would be any problems with bolting the v8 up to the tranny and if any more problems would arise. Looked all over the net and you guys seem like you know what you are talking about so thought I would ask here, never owned a camaro but would love to get it if everything checks out !
Edit: forgot to add that my 700r4 is shot, that is why i have stumbled uppon this camaro, has a good tranny and body, just engine is on its last legs (V6) thats where my engine comes in (V8)
Old Aug 22, 2009 | 01:29 AM
cutmesomeslack's Avatar
Car: 1984 GMC. soon to be 1986 camaro
Engine: Carb'd 350
Transmission: TH 350
Axle/Gears: Stock
Re: replacing a V6 TBI with v8 carb possible ?
please read. this should have the answers you are looking for
https://www.thirdgen.org/forums/engi...swap-read.html
Old Aug 22, 2009 | 01:35 AM
ziggy56's Avatar
yes but it doesn't say anything about the tranny, and what it will run off when i rip the computer out. and if the V8 will fit the Stock tranny thats bolted up to the V8. or if I have to re-gear anything in the back due to a bigger engine. sorry about this but kind of putting all my eggs in one basket on this one. need to make sure it will work before i commit to it.
Old Aug 22, 2009 | 07:00 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
V6 & V8 trans have different bell housing, swap that and you could use the v6 trans I suppose. However, the v6 version is also weaker.
Plenty of people run carb SBC with a 700r4, so that is no problem.
Old Aug 22, 2009 | 08:28 AM
Pocket's Avatar
Car: 91 Trans Am
The bellhousing is part of the case. You cannot simply swap it and even if you did the internals are significantly weaker
Old Aug 22, 2009 | 09:09 AM
Car: 1991 Firebird
Ah.... I wonder what trans I'm thinking of that you can swap 'em......
Old Aug 22, 2009 | 09:15 AM
Pocket's Avatar
Car: 91 Trans Am
Most manuals and newer 4L60E's have a removable bellhousing
Old Aug 22, 2009 | 12:10 PM
ziggy56's Avatar
well i suppose i will go pick it up and have a shot at it. wost case i have to drive with the busted v6 for a while. if it has removable bellhousing it should fit on my v8 then, its a 91 so its the newer 30 spline 700r4. worst case i will need to put my tranny in there and run with no reverse gear for a bit if it comes to it. but mine is a 92 700r4 and it has removable bell housing so i dont see a problem.
Old Aug 22, 2009 | 10:36 PM
Pocket's Avatar
Car: 91 Trans Am
No 700R4's nor 4L60's or any SBC/LT1 style 4L60E came with a removable bellhousing
Old Aug 23, 2009 | 12:14 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It most certainly does!
"1. Anything the V6 bolts to, and anything that bolts to the V6, will be different than the V8."
Old Aug 31, 2009 | 12:40 PM
ziggy56's Avatar
ah well its to late now... pulled the motor and tranny out and...*** IT ! anyone needs a v6 tranny pm me lol. worked all weekend with a few buds got it almost ready.
unplugged all the electrical crap, got the v6 out, put the v8 in behind my old truck 700r4. my 700r4 needs a new sun gear so no reverse but atleast i can go foward . hooked up all the throtle linkage and all that jazz along with most the coolent lines. just need to set the timing and get ahold of some block huggin headers and its set.
I can't get to the heater hose inlets on the firewall because of space, is it possible to just cap off the heater hoses on the block without problems ? or will they have to be hooked up.
and has anyone had problems with hood clearence ? my hood seems to hit the dog dish and the alternator, so i cant close it all the way
Size:  151.6 KBName:  DSCN1694.jpg
Size:  142.0 KBName:  DSCN1696.jpg
Size:  134.4 KBName:  DSCN1698.jpg
Size:  187.0 KBName:  DSCN1700.jpg
Old Aug 31, 2009 | 04:00 PM
five7kid's Avatar
Cut that air cleaner stud down, and get the radiator hose off the top of the alternator and you should be okay.
Old Sep 1, 2009 | 07:13 PM
ljnowell's Avatar
Did you change over the tailshaft housing from the car to your truck tranny?
db057
Jan 10, 2020 08:55 PM
pimp2303
Jul 27, 2017 02:03 PM
CrispyClutch
Carburetors
Apr 11, 2003 05:16 PM
onebinky
Jul 16, 2002 06:51 AM
Diablo4272001
Carburetors
Feb 25, 2002 07:12 PM
