need help advice on getting 305 out of 83 Cam Z28
Old Sep 1, 2009 | 04:01 PM
marksz28's Avatar
Car: 83 camero z28
Engine: looking
Axle/Gears: high performance
i do not have a lift, drive way engine job, Need help and photos on where to place the chains on the block to get it out with an engine hust. this is a fuel enjected motor no carb, so a carb plate is out of the Q. i live in VA i descided to wait till now to get the motor out cause it is getting cooler out. thanks guyyys go GM!!!
Old Sep 1, 2009 | 06:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Fuel injected '83? Must be crossfire.
Are you pulling engine and transmission, or only engine?
If only engine, just put the chain from rear corner to opposite front corner. You can use intake mount bolts, the bolt holes in the end of the heads, whatever.
If you want to get fancy, use two chains - bolt the ends to the ends of the heads, one chain on the front and one chain on the back, and hook them both in the middle of the engine to lift.
Old Sep 1, 2009 | 07:43 PM
marksz28's Avatar
Car: 83 camero z28
Engine: looking
Re: need help advice on getting 305 out of 83 Cam Z28
i need the trans out with it,
Old Sep 1, 2009 | 07:45 PM
marksz28's Avatar
Car: 83 camero z28
Engine: looking
their are two brakets attached to the motor fron and rear can i just hook the chain to those two brakets?
Old Sep 1, 2009 | 11:38 PM
five7kid's Avatar
Yes, but if you pull engine and tranny together, you need the hook toward the back of the engine, and that will tilt the engine side-to-side.
Have you considered a tilt sling?
Old Sep 2, 2009 | 11:11 AM
marksz28's Avatar
Car: 83 camero z28
Engine: looking
tilt sling?
Old Sep 3, 2009 | 12:53 AM
five7kid's Avatar
A beam with a chain on each end. Bolt the chains to the engine. The part that hooks to the hoist is on a screw so you can adjust the balance of the load you're lifting, or tilt one end higher than the other.
Also called a load leveler. http://www.summitracing.com/parts/OTC-4305/
Old Sep 3, 2009 | 12:32 PM
marksz28's Avatar
Car: 83 camero z28
Engine: looking
got it, Cool thanx so much, the engine is in fair condition i was hoping to put on ebay and some money from it, the motor i wantr to put in is a 383 strocker small block. i know that they run from 6,500 to 13,000 all depending on what you have on it. I hope to find one around 4,000 to 6,000 even. Do you know if GM performance 383 engines come also in a turn key set up , or is it just the 383 block no heads or etc?
Old Sep 3, 2009 | 04:19 PM
five7kid's Avatar
I don't believe GM sells a turn-key version. Somebody might.
I haven't seen a turn-key package that I'd buy. Never seen a decent carb in those packages.
Old Sep 4, 2009 | 09:25 AM
marksz28's Avatar
Car: 83 camero z28
Engine: looking
i agree with you on that, i think ill go with jegs. thanx for all your help ttyl.
mark
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
dutch930
Sep 11, 2015 06:58 AM
Reborn756
Sep 4, 2015 03:42 AM
