BEST LT1 SOURCE
Old Nov 13, 2000 | 11:46 PM
1989CamaroRs's Avatar
BEST LT1 SOURCE
is there anywere that sells uses lt1s? can you buy them from GM?
Edelbrock TES Headers, High Flow Cat, Edelbrock Catback, SSM Subframe Connectors
Old Nov 14, 2000 | 02:42 PM
chris1roc's Avatar
I've seen them on ebay and they are in my next gen parts catolog. www.nextgenparts.com
Old Nov 14, 2000 | 03:42 PM
Monkie's Avatar
Man Next Gen is a joke! Why the hell are they so expensive?
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Old Nov 15, 2000 | 02:42 AM
LT1Powered85Z's Avatar
Car: '85 Z28
Engine: 396ci LT1
Axle/Gears: 4th Gen rear with 4.10s/Eaton posi
I've thought the SAME damn thing. Way too over priced for what they are.
Eric
Old Nov 15, 2000 | 05:45 PM
Monkie's Avatar
The sad thing Ive found out is that Next Gen has some stuff that I cant find anywhere else. They do have a good selection and if you dont mind paying $250 on a part that cost $150 in Summit then Next Gen is a goos source.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
Old Nov 17, 2000 | 09:11 AM
TexasLT1's Avatar
Car: '92 RS
I dont remember the name of the company, but there is 1, and I think maybe a second company in the back of Super Chevy that specialize in use LT1's/LS1's, you might want to look there, Also, I don't know if you would want to do it, but I got mine from a company in Houston called Houston Auto Recyclers, just another suggestion
Old Nov 17, 2000 | 08:44 PM
GMFB90's Avatar
http://www.f-bodyparts.com
check them out.
Old Nov 18, 2000 | 07:27 AM
Get Blown ?'s Avatar
Check with these two sites.
http://home.hiwaay.net/~bgraham/
http://www.hpsalvage.com/
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 20, 2016 01:01 PM
1Aauto
Sponsored Vendors
Dec 2, 2015 03:53 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
