305 TBI Swap Out Suggestion
Old Sep 21, 2009 | 04:28 PM
willy825's Avatar
I have a 91' Camaro RS with a 305 TBI. I met a guy who has a factory rebuilt 350 TPI motor with 25,000 miles on it that was meant to go in his 89' IROC. The only thing he said it needs is an intake manifold but he said the one from my motor should bolt right up. Is he correct saying that it will bolt right up? Also if I leave it TPI would I have to change anything else? Or should I convert the new motor to TBI using my old motor? Thank you!
Old Sep 21, 2009 | 05:07 PM
Shadow Z's Avatar
Car: Lots of 'em
Re: 305 TBI Swap Out Suggestion
If your engine is a TBI, and his is TPI, I believe it's not a direct bolt on.
I would definitely convert it to TBI using the parts from your old engine, throttle bodies are almost always more reliable, and have far more potential for modifications, flow wise.
Old Sep 25, 2009 | 02:46 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the motor will physically bolt in place, but wiring and computer are completely different. If you are using your throttle body and intake, everything will fit right in.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
