400 gas sucker
Old Nov 11, 2000 | 03:37 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
400 gas sucker
ok. my source for my 400 just fell through so im reconsidering getting a 350. what is an estimated gas mileage for a 400 with a 850 carb. thanks
also...will a carb automatically make the car NOT pass emissions? what about a throttle body. i would like to pass emissions engine wise...i will have to swap my exhaust manifolds for the long tubes when inspection time comes around. What exactly WOULD cause you to fail...cam, headers, what else. thanks
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 super comp long tubes, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit
MacEwen Motorsports White Gauge Overlays
K&N Filter Charger (wooohooo)
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Old Nov 11, 2000 | 12:41 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
carbs make it REAL hard to pass emissions, a 400 that needs an 850cfm carb will most likely be quite stout and therefore I doubt that with the cam and heads and exhuast and such that u would likely pass anyway. I failed with a 3 inch cat
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Nov 17, 2000 | 03:26 PM
jrr's Avatar
jrr
That catalytic converter disguised as a U-Haul trailer...you may have to help the smog station techs out with that!
Old Nov 27, 2000 | 03:18 PM
JPrevost's Avatar
Car: 91 Red Sled
With an oxygen sensor and cat you should be able to tune a carb to pass emmisions. It might be harder with a large engine and carb.
, Jon (91 RS too many mods to list)
Old Nov 27, 2000 | 09:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No. Negatory. No way. Stop. Cease. Desist.
In LA, you pull into the smog station with a carb, you flunk as soon as the hood is opened. And, they will open it. Speaking as a former resident of San Diego. 1990 Thirdgens did not come with a carb in any way, shape, or form - you will not pass!
Stick with the TBI, or convert to TPI. You should be able to put on a larger TB if you keep the TBI on a larger engine.
There are Super Comps shorties that have the air tubes and y-pipe to connect to the cat. Keep the fact that it is a 350/400 very, very quiet.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited November 28, 2000).]
Old Nov 27, 2000 | 11:27 PM
Car: 90 Camaro RS
Engine: 305 TBI
ok....that carb idea is way gone. now im goin with DFI...only a little more expensive. anyways...how restrictive are the shorty headers compared to 1 3/4 long tubes?
are the 1 5/8 long tubes emissions legal??
thanks guys
Old Nov 28, 2000 | 08:40 AM
five7kid's Avatar
I'm surprised you get any low end at all out of those 1-3/4's on a 305. The 1-5/8's would be a little more restrictive, but would probably still be enough on a smog engine - certainly better than stock manifolds. SLP makes 1-3/4" if that's what you really want. To the best of my knowledge, there are no full-length headers that are emissions legal for thirdgens.
Are you sure DFI is emissions certified? I haven't heard that it has EGR.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
