CENTERBOLT HEADS
CENTERBOLT HEADS
HI,
I WAS OFFERED A 350 WITH CENTERBOLT HEADSFOR 250$, I HAVE A 305 WITH THE REGULAR HEADS RIGHT NOW AND I WAS WONDERING HOW MUCH I WOULD I HAVE TO CHANGE TO MAKE THIS WORK? THE CAR IS A 86 Z28,WITH TPI. THANKS
not sure how far you're going with this, but if it's just r&r of the 305 to 350 it'll bolt right up, nothing differant. the intakes are differant if you do a intake swap. actually it's the center bolt holes that are differant.
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
so everything should bolt right up the same way whether it centerbolt or not? he put me under the impression that there was a difference between the intake because of that. i'm just not sure, i am new at this. thanks
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Most everything will bolt up. The intake center holes are at a different angle so you will need to elongate them to to fit the new 72 degree angle. If you have a two piece rear main seal crank, it will you might find a different bolt pattern on the center bolt motor crank as they have a one piece rear seal, so you would then need that flywheel or flex plate.
Chronologically challenged. But still alive!
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
if it is in good shape take it! the centerbolt motors come with the 1-piece rear main seal, and a roller cam, which is some good stuff.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
-brian
Brian's 1991 RS
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
