what to do when swapping a v-8 into a v-6 camaro
Old Dec 24, 2000 | 06:14 PM
vortech305's Avatar
whats up,
I have a 92 camaro rs with a 3.1 v6 and a 700r4 automatic. IM close to install my worked 88 305 tuned port injection in the car. And im converting it to a t-5 5 speed. My question is what do i have to change for this combination to work I know i have to change the fuel pump can i stay with the stock fuel lines does anyone know what size is the rearend for the v-6 i know its a 10 bolt and also what gears were given in 92 to v-6 motors thanks
vortech 305
Old Dec 24, 2000 | 06:50 PM
Cricket92RS's Avatar
Hey dood, sounds like a lot of us 3rd gen v6ers are going to the dark side. My 92RS has 3.23 rear gears. I know of a few things you will have to change. The throttle cable, front springs, wiring harness, chip inside computer (70 bucks at GM dealer), and you might have to go to the dual fan setup for the radiator if it overheats. To make the tachometer work right you can get the chip that goes inside the instrument cluster, or you can change the entire gauge cluster out and find one from a 91-92 Z28. I changed out the chip until I found a whole cluster and it was easy as pie. As for everything else I have no clue, I am in the process as we speak. However, I pray I don't have to change the fuel pump for the 350 thats going into mine!
I sport a white 1992 Camaro RS 25th Anniversary Edition.
3.1L MPFI V6
A4
[This message has been edited by Cricket92RS (edited December 24, 2000).]
Old Dec 25, 2000 | 04:12 PM
vortech305's Avatar
thanks for the reply if anyone has any answers please answer my question
Old Dec 26, 2000 | 11:01 AM
Coolcars's Avatar
Ok here goes. I've done this change. I don't remember if you said you were going from a Firebird to a Camero or a Camero to a Firebird. Either can be done but it makes the job harder. If you are doning a Camero to Camero swap or a Firebird to Firebird swap you will need to move your motor mounts. the v6 mounts will work but they are in the wrong location. You will need to change the fuel lines the v6 and v8 lines run on oppsite sides, atleast they did on mine. As for the parts for the trans swap I hope you have a complete car you need a lot. The pedals, slave and master cylinder, transmission bell housing flywheel and clutch, you might need the starter and you will need a new chip for the computer. If you are doing the work yourself and you have all of the parts its not that bad just time consuming. If you are paying to have it done sell the car and buy a v8 5speed car and be done with it.
2E,87 Formula 350,with coolant bypass and 160 thermostat and chip. 1986 Z28 with 327 & 202 heads and 5 speed, and usually 4 or 5 others Camaro's & 3 Firebirds to fix, Drive, or sell.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
bellez77
Sep 5, 2015 08:39 PM
InfinityShade
Aug 22, 2015 08:00 PM
reiderz iroc
Aug 13, 2015 04:57 PM
