2.8 to 4.3
Old Jan 7, 2001 | 10:29 PM
Marco's Avatar
2.8 to 4.3
Helping a friend with a 84 Camaro the, 2.8 thru a ROD,(big mess) He has a 4.3 out of a 89 Blazer. I have read through every message posted over the last year and no one has asked about using a 4.3 in a Camaro, Will it, can it, should it fit? if so how bout some pointers. Could really use your help!!
MARCO
Old Jan 7, 2001 | 10:59 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Marco:
First you will have to change the trans. the 4.3 uses the same as a V-8. GM never installed that eng. in an f-body so you will encounter many problems that have not been dealt with such as: manifolds or headers, smog, computer,etc. Be ready for a major challenge.
Don>>>
Chronologically challenged. But still kicking
'92 CAMARO RS
305 TBI 5/spd (now TPI)
'69 camaro-BB,Lenco,1050 dominators
8.97-150+ Pump Gas/no drugs
[This message has been edited by Dyno Don (edited January 07, 2001).]
Old Jan 7, 2001 | 11:19 PM
87RS402's Avatar
The 4.3 is basicly a 6 cyl. version of a 350. I can't remember if the motor mounts are indexed off of the front or back, but that is the only real prob I can see. Exhaust and other things should not be real hard. The computer will most likely need to come from a 4.3 equipped vechicle to use the TBI. I wonder if you can use the puter from a 305 TBI and change the prom?
BTW, I have an 89 blazer that needs a 4.3 has a 700R4 4X4 etc... sell it cheap
Old Jan 8, 2001 | 03:42 PM
psigourney's Avatar
The 2.8,3.1,3.4 are all 60 degree blocks, the 4.3 is a 90 degree block, (350 - 2cyls).
It will take some effort to get it to work. Better choice would be a 3.4 (unless you have a 4.3 laying around )
-Patrick
Working on 85 Cherokee 2.5 -> 3.1 conversion
Old Jan 8, 2001 | 03:44 PM
psigourney's Avatar
Also, the 3.4 was designed by GM to be a more reliable replacement engine for the 2.8 which seems to have big problems throwing rods.
Old Jan 8, 2001 | 04:18 PM
ede's Avatar
ede
all i can say is you never really looked if you didn't see anything by me asking 4.3 questions. part of the problem is i refer to it as my little engine or my 350 -2. too many people will flame you for doing it, as you can see here. mine is going in a 85 drag car. i'm just short of installing the engine.
ICON Motorsports
1st & 3rd
Old Jan 9, 2001 | 06:35 PM
Marco's Avatar
Hay ede,
Does that mean that you have put a 4.3 in a Camaro?
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
