big block conversion
Old Jan 7, 2001 | 10:13 PM
squidly1's Avatar
I got a sweet deal on a 71' pontiac 400. first, iwas wondering if there is some sort of conversion kit for this application, and second, i was wondering if my 700 r4 will hookup with any problems, or problems with the motor mounts, exhaust system, etc. any advice is appreciated.
86 trans am
Old Jan 7, 2001 | 11:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
No. There are no kits available to install a B-O-P engine into a third gen. You'll have to fabricate everything to install it. The tranny won't work because B-O-P have a different bellhousing pattern than chevy.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jan 8, 2001 | 12:11 AM
squidly1's Avatar
im putting the 71' pontiac 400 into an 86 trans am
86 trans am
Old Jan 8, 2001 | 12:39 AM
87RS402's Avatar
I know that Mark28V6 just finished putting his 406 pontiac into an 89 so he could be alot of help if you can get him to read this.
[This message has been edited by 87RS402 (edited January 07, 2001).]
Old Jan 8, 2001 | 12:42 AM
squidly1's Avatar
is there anyway i can contact mark, my email is squidly1@hotmail.com
86 trans am
Old Jan 8, 2001 | 12:43 AM
87RS402's Avatar
Just remembered, a 500 caddy is the same bellhousing pattern as B-O-P and damn close to the same external dimensions as a BBC. There are enough parts and kits to convert parts that if you really want to be a sick puppy......
Old Jan 8, 2001 | 08:31 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Info about my '88 BBC swap is on my page. Some of it might be useful.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Jan 8, 2001 | 08:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The caddy would be an easier swap. You need the Hooker BBC headers and the caddy exhaust flange that's available from places like Cad Company. You cut off the BBC flange and weld on the caddy flange and you then have caddy headers. You'll still need a tranny with the B-O-P bellhousing.
Old Jan 10, 2001 | 02:30 PM
RoadRacer's Avatar
If you wanted to use a BOP motor, you could alwas just get a 700r4 or 200r4 out of a junkyard BOP car and use it. Everything else should be the same . . .
Don
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
LittleFranks
Oct 7, 2015 11:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
