'89 2.8 wiring for ZZ4 HEI
Old Jan 17, 2001 | 07:48 PM
89V6toV8's Avatar
I've been tinkering on my '89 Firebird for the last 2 years turning it into a high performance street car.
My question is related to properly wiring up my distributor. I'm installing the distributor that came with my ZZ4 and also using an MSD 6A box and Blaster II coil. What wire would be most appropriate for the switched power lead for the MDS box? I assume it's one of the original wires that connected to the factory distributor.
Also, which of the factory leads is my tachometer gauge driver signal? Can I simply plug that wire into the tachnometer output from the MSD box? I don't want to trash my tach by hooking up a 12 volt supply if it was supposed to be 5 volts or something like that. A buddy of mine already recalibrated my tach from 100 rpm to 8000 rpm using a variable pulse generator so that's not a problem (in fact, it's so highly accurate now through that entire range it's amazing!).
Thanks!
lt500r55
Sep 1, 2021 01:30 PM
Cleotiz
Jan 6, 2018 08:56 PM
stalkier
Aug 21, 2015 01:54 AM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
