3.1 V6 to a 350 swap
Old Oct 8, 2009 | 09:42 PM
Pyronight's Avatar
Car: 91 firebird/68 Camaro
Engine: 3.1L V6/Ram jet 350 crate
Transmission: T-5/L60E
Axle/Gears: 7.5 10 Bolt/3.90 posi
I am getting rid of the stock 3.1 v6 for a 350 block. My quick question to all the motor gods in here is this.... will it fit the stock motor mounts or will I have to modify my mounts? It is a 1991 firebird stock.
POUR FORTH YOUR KNOWLEDGE!!!!!
Old Oct 9, 2009 | 07:35 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 3.1 V6 to a 350 swap
Don't know if the mounts are different - a check of part numbers at autozone.com would tell you. I do know they need to move forward as the V8 is longer, but there are mount holes already in the subframe.
Try - there's a ton of threads and stickies on V6 to V8 swaps.
Old Oct 9, 2009 | 02:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The info is in the V6 to V8 swap sticky in the top section of this forum.
3.1EyeCandy
Oct 7, 2001 03:36 PM
3.1EyeCandy
Oct 7, 2001 03:34 PM
Drew
Sep 11, 2001 10:28 AM
ADAM NEAL
Jun 5, 2001 09:31 PM
