Is this a good motor?
Old Jan 30, 2001 | 06:19 PM
BairsZ28's Avatar
Here is a list of the what has been done and is included:
1978 '509' block 2 bolt bored .030 over and honed w/ deck plates
L2352 +.030 TRW forged piston w/ speed pro plasma moly file-fit rings
400 crank mag'd ground and indexed
400 rods mag'd resized w/ milodon rod bolts
blue printed melling oil pump w/ sleeved shaft
cloyes double roller timing set
long slot rocker 1.6 int. and 1.5 ext.
comp custom hydralic camshaft .477 int,.480 ex. 218deg. int, and 230deg ex @.050, 112deg lobe centers
Dart SR Torquer heads port matched bowl ported w/oversized valves (2.08 int. and 1.625 ex.) steam holes drilled, resurfaced min.
Edelbrock performer egr intake
Jet Performance Electronic Q-jet set up for this engine
Comes w/oil pan, front cover, balancer, automatic flywheel (168 tooth)
Engine is balance to within 1 gram.
All of this for $2500. Is this a good deal?
Old Jan 30, 2001 | 07:32 PM
89V6toV8's Avatar
Used motor? Not a good price. Far too expensive.
New motor? Barely a fair price. Not what I would call a good deal.
From your description, the motor is going to be a weak performer. Very mild setup that will be an average street performer. Don't expect to win many races with this one.
Old Jan 30, 2001 | 08:42 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Well its a 383, decent parts. NO, you won't be cleaning up at the track, but it will be a nice street motor.
Biggest question, is this a fresh rebuild or pulled from a running car? If this is a used motor with a fair number of miles, the price is on the high side. If it is a fresh rebuild with no miles (other than being test fired), it's not a bad deal. Does it have a warranty?
If you had to pay someone to build it to those specs you'd probably pay more. Just for the laugh of it, call a couple of machine shops and tell them you have a 350 core that you'd like to have built like the one you are describing. And then ask them how much of a warranty you would get.
Old Jan 30, 2001 | 11:02 PM
BairsZ28's Avatar
Sorry, I forgot to mention that this is a fresh rebuilt motor and it's a 400 block, 412ci with the bore and stroke. It was being built for an 84 Z28 but the guy he was building it for back out. I went to check it out today and it wasn't completely assembled, the short block was done, and the heads were done but not but on. Is the .030 over bore too much for the engine, and are the vavles too big? Thanks for the replies.
Old Jan 31, 2001 | 03:13 AM
Novaguy76's Avatar
The heads, cam and intake are the only things holding this motor back. If you can get a differant set of heads, a bigger cam adn a beter intake it would be a realy good motor. This motor the way it is should be good for something around a high 13 in the 1/4 wich is nothing to laugh at (would run about like a stock LT1 Z28 does) but is defanitly not the fastest thing out there. The cam that is in there is the Extreem energy 260 or 268 cam (I can not remember off the top of my head), if you put in the extreem energy 274 or 284 cam with a Performer RPM intake and a better set of heads then that would be good for an easy 12 in the 1/4 and still have room for lots of nitrous with those forged pistons. The price is not to bad or that motor and it is a great place to start. You could always put it in and sence you will not have to worry about the bottom end again you can just bolt stuff on as money allowes and watch as it just gets faster and faster.....lol. I say buy it and happy building
82 Z28 with 350.motor has .030 forged flat top pistions other wise stock bottom end, Summit 214/224 cam with 1.6 Harland Sharp roller rockers, stock 882 heads for now (will be getting a set of the 23 degree Trick Flows this summer), Performer RPM intake, Holley 750 Vacuum secondary, Th350 with 2200 converter, stock 3.23 geared rearend for now (getting 9" later on), Headman shorty headers, custom 2.5" into 3.5" Y pipe into M.A.C. offroad pipe and M.A.C. cat back system. So far car has only been to the track twice and is having sever traction problems but is running 60'-2.34 1/8 mile-9.2 @ 79 MPH.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
cstrobel65
Aug 15, 2015 10:19 AM
fonzie85
Aug 13, 2015 11:50 AM
slade5612
Aug 11, 2015 07:19 PM
squiggy2
Aug 9, 2015 09:30 PM
