Wiring GM HEI on '89 2.8
Old Feb 14, 2001 | 10:10 AM
89V6toV8's Avatar
I asked this question a while ago but nobody replied. In the mean time I've figured it out and I thought I would share the solution.
The 12-gauge pink wire going to the original 2.8 coil is the battery wire you should use for the distributor. The accompanying white wire hooked up to the coil with the test terminal poking out of the wiring loom is the tachometer signal for the gauge in the dash.
Problem solved
Cleotiz
Jan 6, 2018 08:56 PM
fbirdroller
Sep 2, 2015 10:27 PM
stalkier
Aug 21, 2015 01:54 AM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
