ZZ4 or 350 HO???
Old Feb 14, 2001 | 11:24 PM
Brian92RS's Avatar
ZZ4 or 350 HO???
Ok, i know that the 350 HO has a flat tappet cam, and iron heads, but the deluxe model comes complete with carb and everything and is 3k. A zz4 is about 3,300 and still needs a carb.... But it's got a roller cam, and aluminum heads.... Decisions decisions!!!
1992 Red RS with 305 TBI
Old Feb 15, 2001 | 01:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The HO has Vortec heads (iron, like you said), with press-in rocker studs and rather lift-limited springs. If you want to upgrade the cam in the future, you'll want to address those items. Flat tappet performance cams are cheap.
The ZZ4 has screw-in studs and decent springs, so cam upgrade won't require upgrading those pieces. But, roller cams are a good bit more coin than flat tappet (although you could put a flat tappet cam in - but, why, would you do that?).
$/HP, even with needing to rework the Vortec heads, you'll get to 355 with the HO for less money than the ZZ4, assuming you do the disassembly and reassembly work. Beyond that, the ZZ4 will start to take over. And, HP/pound, the ZZ4 wins hands down.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited February 15, 2001).]
89fast5oh
Sep 8, 2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
