First Engine build need advise
Old Oct 17, 2009 | 02:19 PM
86ta985's Avatar
Car: 86 Trans Am
Im looking to buid a streetable 350 to put in my 86 ta. Want something carb. around 350-400 hp. any suggestions on certain combos, heads cams intake carbs?
I am looking for a 4 bolt main 350 with the two piece rear seal.
Old Oct 17, 2009 | 04:23 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: First Engine build need advise
vortec heads are cheap and easy to find. go with a summit 1102 cam kit its cheap and i have one in my s-10, good power and torque. use edelbrock 7116 intake. keep compression between 9-9.5:1. 600-750 vac secondary carb. good luck
Old Oct 18, 2009 | 04:32 AM
86ta985's Avatar
Car: 86 Trans Am
Thats exactly what ive been reading on different sites. You've just made the decision for me. Thanks alot. Vortec heads and the intake for sure. you dont happen to have a sound clip of the truck running with that cam do you?
And what would you reccomend as far as a carb?
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
