Will the 350 HO Crate fit manual trans?
Old Feb 22, 2001 | 10:50 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I've been eyeing that 330 hp crate engine for a long time now, and was wondering if it will actually fit behind the stock T-5 which will have to be changed to a T-56 probably shortly thereafter.
Pat Hirsz
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
Run a best of 16.7 @85mph before gears
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Feb 23, 2001 | 12:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would recommend putting it ahead of the T5...
Yes, fit it will. You'll need to insure you have the correct flywheel for the rear main seal type. Otherwise, happy fitting!
P.S.: You're sure making me feel good about my 130k miles LG4's best of 16.71 at 5800' Bandimere in a breakout run (I was backing off). That was with 3.08 open, otherwise mods listed that have actually been accomplished.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Feb 23, 2001 | 12:37 AM
Car: 88 IROC
Transmission: auto
I know, its kind of embarrasing, i think my clutch is slipping.
Old Feb 24, 2001 | 10:30 PM
JPrevost's Avatar
Car: 91 Red Sled
87 and up had the one piece rear main and so does the 330ho engine. You should have no problems bolting it but I would definatly get a new clutch too. The t-5 isn't exactly the strongest trans either, GM wouldn't even put a 350 with one if that says anything. Just be careful with it and don't be dumping the clutch too often.
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
milk
Aug 10, 2015 06:26 PM
