whats the process?
Old Feb 23, 2001 | 02:43 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
whats the process?
how would i go about installing a new engine by myself? i have a 1991 rs with a 3.1 v-6. I am going to put a 305 TPI into it. I am keeping my current 5 speed. I was told I can do this and i was told how to do this, so please don't worrry about that. I need to know what other things i will need to replace and how to go about pulling the old out and putting the new in.
Old Feb 24, 2001 | 11:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm getting mixed signals here. You say you've been told you can do it and how to do it, then you say you need to know how to pull the old out and put the new in. Hmmmm....
I'll take a stab at what you're trying to ask. I'll assume you mean you know you can keep the T5 if you use a V8 bellhousing.
As for the rest, go buy a TPI car close to your year that's been totalled from a rear or side collosion. Then change everything associated with the V8 & TPI (harnesses, lines, cables, hoses, fuel pump, computer, radiator, accessories, etc.) and the front springs & engine mounts. Don't forget the tach.
Is that close to what you needed to know? There's plenty of posts about switching from V6 to V8 on this board - just look over the topics from the last 30-45 days or so.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
84redta
Sep 19, 2015 09:58 AM
Doobie52
Sep 11, 2015 06:19 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
