Build or buy?
Old Feb 27, 2001 | 07:36 PM
jkvette719's Avatar
Build or buy?
Should i buy a block and rebuild a 350/355 or buy a crate motor from GM Performance? Should I use the TPI or carb.? Will i get anymore power outta one or the other? I want atleast 350HP. Which would be better/Cheaper? Thanks Justin
Old Feb 27, 2001 | 08:40 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Crate motors are sweet & easy with a guarantee (usually). Good machine shops are expensive and won't guarantee it if you put it together (usually) or at all if they did (sometimes). If you figure all the labor time you put into it a crate looks like a good deal. Unless you have a lot of time on your hands and alot of specialty tools already purchased.
I'm split down the middle but leaning towards crate power.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Feb 27, 2001 | 08:48 PM
jkvette719's Avatar
im not building nothing, its all going to be done there, down to the cam. Ill put on the starter, dist and all that. Just the main stuff, i dont have the right tools to do it all right....thanks
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
Gunsbee
Sep 7, 2015 07:10 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
