305 heads on a 350????
Old Mar 25, 2001 | 12:24 AM
Iroc Detroit's Avatar
Planning on swaping my tired old 305 for 350 but was wondering if the 305 heads would work? They will need to be rebuilt,so is there anything the engine shop can do to them or do i need to buy new heads!
1985 Camaro Iroc Z
305 Tuned Port Injected
Old Mar 25, 2001 | 08:47 AM
Imark's Avatar
Although they may fit, the compression ratio would go up quite a bit. 11:1 or so. Plus they won't flow enough for the 350 to use it's true power. After the machine work that would be required, it would probably be just as cheap to get some used 350 heads and have them rebuilt. Just a thought.
"It's not about going fast all the time; It's knowing you can, anytime"
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
