which cylinder heads
Old Nov 4, 2009 | 10:39 AM
One_Nasty_Z's Avatar
hello im looking at swapping in a 355 sbc. im looking at putting in a edelbrocke roller rocker camshaft
http://www.summitracing.com/parts/EDL-2204/
thants the camshaft imm looking at running. it hass 882 heads right now but ive heard bad things about them and want to look into diff options. so im wondering what kind of camshaft and intake i should run. i have a edelbroke 600 cfm carb. its going to be basically a street motor and i dont mind running 93 octane gas cause i usually do anyways but no higher. ive been looking at trick flow 23s im just not sure on the whole intake runners and all that stuff so let me know what yall think. thanks
Old Nov 4, 2009 | 10:52 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: which cylinder heads
Well, it is a roller lifter cam shaft, not a roller rocker.
Vortec heads would fit the bill pretty good for you for the price. But if you have the money, a set of Patriot heads are outstanding for the pricee.
Old Nov 4, 2009 | 11:58 AM
yeah thats my bad. the vortec heads were and option but everyone says u need to do a bunch of work to make them worth a crap. the average price for good flowing vortecs after machine work is like 600 top 700 bucks. a nice set of trickflow 23s is 1100 bucks. i think id rather spend the money to get top of the line heads and build serious power. my real question is with this set up what size of intake runners and combustion chambers should i be looking for to acheve maximum power
Old Nov 4, 2009 | 01:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's about the best description for those carbs I've ever heard.
Top of the line heads and a bottom dweller carb - not the right combo for "serious power".
You'll want heads in the 180-200cc intake port range. AFR would fit the "top of the line" part. Or Brodix. Vortecs would be a big jump over 882's. This is a hard deal to beat http://www.sdparts.com/product/SD806...RPMAirGap.aspx . But, they are only 170cc heads, so look at AFR offerings.
The 882's and "Edelbroke" carb have got to go.
Old Nov 4, 2009 | 02:41 PM
well ill thats what i have right now. what do u suggest for a carb then. and yeah afrs and brondix are both good but im kinda partial to trick flows super 23s with 195cc intake runners how do those sound?
Old Nov 4, 2009 | 07:37 PM
five7kid's Avatar
750 Holley double pumper.
Probably okay. The guys making real power tend to go with the AFR's or Brodix.
Old Nov 5, 2009 | 06:49 AM
well ive been lookingandtrickflow makes real power as well. the numbers those heads put up are very impressive and they are pretty affordable compared to those two
Old Nov 5, 2009 | 07:31 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Pro comp heads are great for an aluminum head at a cheap price. A lot of other members have posted good results with them here :. Super Chevy also did a budget build with them and put down some got nice hp numbers.
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
