305 tbi to 350 tpi harness
Old Nov 5, 2009 | 11:41 AM
luckytempo93's Avatar
i bought a 350tpi engine with the computer and harness under the hood. are the computer harnesses inside the vehicle different between the tbi to tpi? cause im going to the yard saturday and want to pick up a harness inside from the computer to the firewall. thanks
Old Nov 6, 2009 | 03:31 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 305 tbi to 350 tpi harness
Dash harnesses are similar to a point
V6 and TPI's interchange
You much match trans type. TBI harnesses are slightly different regarding the VSS
Old Nov 6, 2009 | 04:59 PM
ok well this is what im doing. i have a 1992 rs 305tbi auto. and im taking the auto and engine out. and installing a 5 speed and the 350 tpi. and im looking to put the tpi computer in the car... will the 305 tbi/ auto harness plug into the tpi computer?
Old Nov 6, 2009 | 05:25 PM
Pocket's Avatar
Car: 91 Trans Am
No
Do a search on TBI to SD TPI wiring conversions and then check out auto to T5 wiring conversions. You're doing both
Old Nov 6, 2009 | 05:37 PM
what is sd tpi
Old Nov 6, 2009 | 10:29 PM
Pocket's Avatar
Car: 91 Trans Am
Speed density
Old Nov 7, 2009 | 08:58 AM
ya i figured it out as soon as i sent it. im going to the yard to find some stuff and im hpoing to find everything i need right now
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
