350 top end build up list take a look
Old Nov 5, 2009 | 01:15 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Transmission: 9" tail th350 B&M stage 2 shift kit
Axle/Gears: 4.10
I want to build a 383 stroker engine for my 84 firebird. I want to build a street/strip engine with about 425-450 HP and TQ range. I have made a TOPEND parts list that i think will achieve the power i want with the budget i currently have.
For the build I choose:
Patriot Performance GM Vortec 185cc Cylinder Heads
http://www.jegs.com/i/Patriot-Perfor...ductId=1192214
This seems like a really good deal to me for a set of complete cylinder heads vs buying stock vortec heads and having them all machined and buying stiffer springs and all the other stuff .Has anybody ever used this cylinder head or heard any reviews on it.
Comp Cams 'Xtreme Energy' Hydraulic Flat Tappet Camshafts
Street/Strip, 2800+ stall, likes headers & gears, rough idle.
Operating Range: 2300-6500 RPM
Duration Advertised: 284° Intake / 296° Exhaust
Duration @ .050'' Lift: 240° Intake / 246° Exhaust
Valve Lift w/1.5 Rockers: .507'' Intake / .510'' Exhaust
Lobe Separation Angle: 110°
http://www.jegs.com/i/Comp-Cams/249/CL12-250-3/10002/-1
Proform Aluminum Roller Rockers
1.6 ratio, 3/8" stud
Professional Products, CrossWind Dual Plane Intake
http://www.competitionproducts.com/p...p?number=52028
1500-6500 rpm
I currently have a small block 350 in the car with
3970010 4 BOLT BLOCK
STOCK CRAPPY HEADS HOME PORTED AND GASKET MATCH TO INTAKE
STOCK CRANK
STOCK RODS
FLAT TOP PISTONS
ROLLER TIP ROCKERS
TORKER 2 INTAKE
UKNOWN CAM SUPPOSELY RV CAM
MSD STREET FIRE DISTRIBUTOR
AUTOZONE WIRES
EDELBROCK 600 CFM CARB
I HAVE 1 5/8 HEADERS WITH 2 1/2 DUAL EXHUAST FLOWMASTER SUPER 44S
I HAVE A TH350 TURBO 9'' TAILSHAFT WITH B&M STAGE 2 SHIFT KIT IN IT
AND I NEED A STALL CONVERTOR TO MATCH THE CAM I WAS LOOKING AT THESE ONES.
JEGS Torque Converters
GM TH350/TH400 10" Converter
10.75"/11.5" dual bolt circle
Stall Speed: 2700-3000 RPM
http://www.jegs.com/i/JEGS/555/60401/10002/-1#
Power Products, Perf. Torque Converter
GM TH350-400, 10"
GM TH350-400 (10.75" Bolt Pattern), 10" (3000-3200 Stall)
http://www.competitionproducts.com/p....asp?dept=1299
I will eventualy end up makeing my 350 into a 383 stroker with this top end. I think i covered just about everything I wanted to. If any of you have used these products let me now how they are I would greatly appreciate it. Also tell me about your killer street/stip combos and if you think this is a good combo or not or what you would change.
Old Nov 5, 2009 | 08:19 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 350 top end build up list take a look
Sounds good, get a 3000 stall, that way it will stall to 2500 foot braking. Ought to be close to 500 HP.
Old Nov 6, 2009 | 12:25 AM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
Thanks for the post now I just got to save up my pennies lol
Old Nov 6, 2009 | 02:17 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Good luck with it. I find that the more money i make, the more i want to spend that i dont have....never happy. The big block swap is killing me.
Old Nov 6, 2009 | 07:35 AM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Do NOT get either of these products. Yes the Pro Products intake flows about as good as the Edelbrock but its a cheap casting knock off and I personally would not recommend it.
However what ever you do STAY AWAY from Proform rockers. They have a major design flaw and have been known to completely come apart in even mild set ups. Go with comp or harland for your rocker needs.
http://www.youtube.com/watch?v=DxROQtv7o2A
Old Nov 6, 2009 | 08:54 AM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
thanks for letting me know about these products.
Old Nov 6, 2009 | 11:02 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I agree on the rockers. However, the professional products intakes are great. No one has any issues with them and they are solid. So, get the damn intake and save some cash.
Old Nov 6, 2009 | 04:06 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
should i go with a single plane intake such as the hurricane intake
Old Nov 6, 2009 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No. Stick with a dual plane.
Old Nov 7, 2009 | 12:15 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
The RPM air gap knock off is the best money can buy. Dual plane and it will rev to 7000 if it has to. But it keeps the bottom end TQ a street car needs.
Old Nov 7, 2009 | 01:42 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
I dont plan on taking this motor over 6500 rpms
Old Nov 7, 2009 | 11:15 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, the knock off air gap is just able to do it, it is great for low end TQ.
Old Nov 8, 2009 | 01:31 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
https://www.thirdgen.org/forums/afte...s-intakes.html
https://www.thirdgen.org/forums/afte...fessional.html
https://www.thirdgen.org/forums/afte...manifolds.html
Old Nov 8, 2009 | 01:35 AM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
i use to be into 4.6L mustangs and thats where i first tried one of professional products knock off pieces. There is a reason it's called a knock off and not the real thing. Spend a little more and get the Eld the quality is so much better.
Old Nov 8, 2009 | 03:10 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, and several people are telling other to quit bitching and do some port work and it is fine.
**** happens, and FYI, here is a god damn almighty elelbrock intake that is NAME brand we put on my buddys malibu with a LSx. So for the bitching about "buy american", there it is. Your post is not such a valid statement.:
http://www.lsxnation.net/showthread....cracked+intake
Old Nov 8, 2009 | 08:07 AM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Sounds like someones getting a little butt hurt. I never said to buy american, i just said this particular company blows IMO. I don't thinking anyones bitching, except maybe you.
Old Nov 8, 2009 | 12:08 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I don't really care where the parts I buy are made, I just try to buy quality parts, and as far as I can tell, Porfessional Products products don't seem to be good quality. I bet you could find 10x the complaints from people bitching about PP as you could Edelbrock or Weiand.
Old Nov 8, 2009 | 01:13 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Nope, not in my feelings. My PP intake is fine, no problem at all and is a great casting. So i have no complaint, the people YOU posted are bitching. They said buy american, so like i said, look at the post where the almighty eldeljunk is cracked around the ports.
I like them, but the fact is that they are a direct knock off of a edelbrock casting. 95% anyway.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
