Motor Swap Questions
Old Mar 29, 2001 | 04:28 PM
taughtmepatience's Avatar
I just swapped a 350 truck engine into a 87 Z28 that orginally came with a carbed 305. I am having a few problems that someone may be able to give me some advice on.
1)The oil filter blocks the exhaust pipe from connecting to the manifold. Can I get an adapter for the oil filter, or do I have to reroute the exhaust pipe?
2)will the CC carb still work with out any of the smog equipment still attached or should I get a manual carb?
3)Do I need an oil cooler? I'm not sure if the old 305 had one.
Thank You for any imput.
project '86 Z28
bone stock now
350 coming soon
Old Mar 29, 2001 | 08:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1) You'll need to use third gen exhaust manifolds or maybe use a shorter filter.
2) no idea
3) Engine oil cooler? Probably not. Most cars don't have them including my race car.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Apr 1, 2001 | 12:26 AM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
your carb will work but it will probably not work as well a non computer controlled carb. My advice is to buy a new non controlled quadrajet or a used one and rebuild it. I unhooked the computer garbage on an old monte carlo I had and it really started to drink gas.
Old Apr 1, 2001 | 02:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"If it ain't broke, don't fix it (unless you can make it better)." I added that last part myself.
Going non-CC will not make it "better". In a lot of ways, it'll be worse: gas mileage, TCC lockup, emissions, for instance. The only things that will need to be made "better" on the CC carb/ignition are secondary rods/hanger and air inlet (unless you already have the dual-snorkel air cleaner). The first is tuning, the second would have to be done with a non-CC carb/ignition.
Now would be the time for headers and high-flow cat & exhaust. The 305 pieces choke a 305, let alone a 350. That will solve your exhaust/filter interference.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Apr 1, 2001 | 07:40 PM
Thank You for the info. You help is greatly appreciated.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
reiderz iroc
Aug 13, 2015 04:57 PM
