305 to 350 swap with probs
Recently I threw a rod in my 89 RS and in a desperate attempt to find another 305 was impossible for me at a descent price. I replaced it with a 350. everything works fine when I start it for the first time each day, but after I run it for about 15 minutes, It seems like it starts to flood. idles fine, but when I put it in gear it just all of a sudden dies out. evens happens like if I'm stopped at a stoplight. If I let it sit for about 3-4 hours then everything is fine again. HELP!!!!!!!!!!!
Transmission: 4L80E/4L80E
Does your "Service Engine Soon" (SES) light come on? If so, the computer is setting a trouble code, which will help point you in the direction of your trouble.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Bad news guys...the service engine soon light has been on since 1990, because My dad hit a deer in it and totaled it out...we bought it back and rebuilt it. so even with the 305 in it the service engine soon light was on.
Car: 91 Red Sled
Pull some codes and they'll tell you what sensor is bad. Replace and be on your way. I don't see the big problem except if you don't know how to pull codes.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
, Jon (350 TBI!)
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
Car: 91 Red Sled
https://www.thirdgen.org/faq/thirdgen.shtml#misc
, Jon (350 TBI! getting 23mpg highway)
- 8" harm. balancer
- Alston SFCs
Right under the instructions for how to get them in the link above. My Haynes manual also has them, and the "code readers" you get from Checker/Pep Boys/Auto Zone also have them.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i am having basicly the same problem, i read the tech artical, where is the connectors that i am supposed to short.?? are they in the dash, with the ECU???
thanks
thanks
It's above your right shin when you're sitting in the driver's seat. A cover, about .5" x 2", is over it (if the cover hasn't been lost).
Typically, it can't be seen when sitting in the seat, so bend over and look for it.
