305 tbi to 350 tpi......Help me out!!!!!
Old Mar 30, 2001 | 09:44 PM
Happy17yearold's Avatar
Okay I am a complete novice and have just started discovering the life of an F-body over the past two months.I bought a 305 tbi and i think the motor is very reliable and more then i can ask for as my first car.I dont want to invest alot of money to mod my 205 just to have a 350 stock come around and spank me.I can get a 350 tpi with computer for 700.I will be rebuilding it and adding stuff but my question is about what else i will need to make the transplant a success.
1988 Trans am.......best 600 bucks ive ever spent...305 5.0 but will save my lunch money and every penny to swap for a 350 tpi in the coming two years
Old Apr 2, 2001 | 12:07 AM
SUPER-SPORT-CHEVY's Avatar
Well the best and i say best cause its easy is to spend 999.95$ and get an edelbrock www.edelbrock.com/ "3502" its a tpi thats a replacement for tbi on a truck will also work an a camaro/firebird. Its alot easyer than tring to plug wires into something that was not ment to be messed with.
Btw did you cut the cat off?
Old Apr 2, 2001 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Waste of money. If you're getting the engine and computer, try to get the wiring harness that goes from engine to computer, and in-tank fuel pump. That's assuming you're also getting fuel hoses; distributor; air intake; throttle, cruise & TV cables; engine harness; injectors; regulator; accessory brackets; etc., etc., etc.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Apr 2, 2001 | 05:56 PM
Whats a waste of money??
Old Apr 2, 2001 | 09:47 PM
Actually This "3502" is supposed to be a bolt on and plug in aplication an easy in and out.
"Direct replacement"
I dont know for sure but it looks like this kit's complexity level is swaping a manifold and splice 4 wires. Fuel rail inlet is in the same location as a tbi.
Old Apr 5, 2001 | 01:13 PM
IROCZ88's Avatar
I looked into that edlebrock setup when I did my swap. The $999 doesn't get you everything such as the fuel pump and I think there was something else. Read between the lines!! Plus I called edelbrock and they said I had to get a computer out of a truck and that meant my wiring harness wouldn't work. So there's another $350 spent sending it to Howell which I did anyway with the TPI. Note that this setup is designed for trucks not our cars. Plus, with the truck computer something would have to be done with tranny and lockup controls. If you have a truck this is a great setup, but it's a pita and more expensive with a thirdgen.
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Apr 5, 2001 | 02:07 PM
five7kid's Avatar
That's why it's a waste of money. I have seen the conversion on a truck, it's better than the TBI but not all that impressive (I drove it as well). But, as stated, it is for '93-newer TRUCKS, not our 3rd gens. It gives you nothing you can't get with salvage parts for a lot less money, and doesn't offer any performance advantage.
Repeat, the Edelbrock conversion system is a waste of money for what he's starting with.
Old Apr 5, 2001 | 02:23 PM
IROCZ88's Avatar
Actually it's for '87-'95 trucks. I agree, it is a waste of money on our cars, might not be bad on a truck though.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
