bye bye 305
bye bye 305
im tired of trying to fix the problems with my 305 HO in my 84 TA......i wanna go with a 350......what all do i need for this swap? can i keep some of my 305 parts? and anything i have to keep in mind when doing the swap....btw its a 305 4bbl auto that im trashin......
If your having "engine problems" just get a 350 that will drop in. You wont have to reuse any parts except for the "mainfolds" sensors carb/tbi ect ect. I highly recomend a gm crate engine Ho or not cant beat a 3year 30,000 mile warenty.
Transmission: 4L80E/4L80E
What problems have you been trying to fix? 95% of the typical problems are outside of the long-block - putting in a 350 won't solve a thing.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
I agree!!
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
well right now im not geting any oil presure i dont think since it ran for about 20 mins and inside the valve cover its bone dry.....but the engine is old and just looks in rough shape.....and i just know **** about engines.....so a little problem for me is a big problem.....i do want to keep the 305 but im having a hard time figuring out all the problems
seems to be the oil pump!
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
3inch
njdaewoo@excite.com
