327 in 89 Formula
Old Apr 9, 2001 | 11:00 AM
5spdTPIFormula's Avatar
327 in 89 Formula
I have a 69 327 sitting in my garage that was for a different project, but I decided I want to put it in my Formula. It is bored .030, and has a cam (Stock for 350hp 327). It has .488 lift on the intake and exhaust. I don't have heads on it, will the stock ones on my 305 work? I would have a valve job done, but don't have the cash to pony up for new heads. I also want to use my TPI setup. Will all of this work? What do I have to do to the computer? Thanks for your help.
Kevin
Old Apr 9, 2001 | 12:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 327 is a great engine, but 305 heads will kill it. It will run, but compression will be very high, flow will be very low, and that cam will stress your press-in rocker studs and stock 305 springs.
You would be much better served getting heads with 1.94 or 2.02 intakes and 1.60 exhaust valves, better flowing ports, and 64cc chambers. World S/R Torquers or Sportsman II's would be a big impovement, come with screw-in studs, and springs can be matched to your cam. There are more choices as well. You didn't say what year your Formula is, but if '87-later, you'll need heads that work with the center two intake bolts being at a different angle.
The dipstick will be on the driver's side, and won't fit with your stock manifolds. Headers will most likely cure that, or get a pan with the dipstick in the side wall on the passenger side.
Your computer won't complain much, but you might want to find out what the cam lobe seperation is (too little might confuse it). You'd get more performance out of it with an adjustable fuel pressure regulator and peformance chip. Certainly go with the AFPR, even if the chip has to wait until later.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Apr 9, 2001 | 07:50 PM
ede's Avatar
ede
there were no '69 327s. you might want to check again and see what you have. 327 is a 4" bore by 3.25 stroke. get the engine id off the pad in front of the right head and look it up at www.mortec.com
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 9, 2001 | 10:17 PM
jms's Avatar
jms
Chevys had 327s in 1969. Most of which were 2 barrel big car engines. This was the last year for the 327. Only '68 and '69 had the large journal cranks.
jms
Old Apr 10, 2001 | 10:56 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
I have to disagree!!! I have a LJ 1969 327 on the stand right now...The crank castinging # is 3941174 cast and was used in 307 and 327 blocks...I could get the block casting number when I go home next time if you would like more proof.. Kevin
Old Apr 10, 2001 | 12:33 PM
five7kid's Avatar
Absolutely. 327's last year was 1969, and as said, the '68 & '69 versions had the large journal cranks (got bit by that when overhauling a 327 truck shortblock for my '57 in 1972 - got the wrong bearings, but NAPA exchanged them).
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
