idk what my motor is
Old Nov 11, 2009 | 09:12 AM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
i got a motor replaced before i owned the car the intake number is 10108449 its got tbi
and there is a clock number 16 and there is a small badge next to that with a 26 j4 thats all i could find i did research but couldnt find a exact motor plz help thx
Old Nov 11, 2009 | 03:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Insufficient data.
Most likely you've got a 305 TBI LO3. But, if the engine has been replaced, the intake info tells you nothing.
You need to get the casting number off of the block at least. The full number is above the bellhousing mount behind the driver side head. The last three digits are the most important, and often they are cast into the sides of the block in big numbers (easier to see once you get the car off the ground and crawl underneath than trying to read the numbers off of the back of the block with a mirror and flashlight in a cramped space).
The head casting numbers would be good to know as well. Those numbers are under the valve covers, so you have to pull the valve covers to find them.
Old Nov 12, 2009 | 05:41 PM
Car: 84 Trans Am
Re: idk what my motor is
yea i found the casting number on the back driver side u know GM ###########
but i only saw two rows of numbers and they were to short to be casting numbers
ill look under the motor and will find some numbers
Jae992
Aug 27, 2015 09:07 AM
B_Dubya
Aug 26, 2015 05:09 PM
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
1985chevydude
Aug 20, 2015 12:29 AM
