Chevy 355 Oil Pressure
Car: 83 Z28
Engine: 355
Hey guys, on a 355 what oil pressure should I be expecting? It starts high when cold, 40-50, but once warm drops to 12-15 sometime going back to 20. Is this normal? Seems a little low to me, but I am new to the engine. Thanks.
Car: 1986 IROC-Z
Engine: 420HP ZZ4 350
Transmission: TH350
Axle/Gears: 4:11's
Re: Chevy 355 Oil Pressure
Dont know if this will help or not, But I have a ZZ4 350 that runs between 10-15psi when idle at operating temp(180-195). and between 40-45 when crusing.
Transmission: 4L80E/4L80E
The rule-of-thumb is 10 psi per 1000 RPMs when warm.
40 psi is factory stock for the typical SBC. Surprising to me, my 6.5 turbo diesel only runs 40 psi.
(FWIW, my ZZ4 pump runs a lot higher than that, more like 70 psi cruising warm and 40 psi at idle warm.)
Car: 1986 IROC-Z
Transmission: TH350
Axle/Gears: 4:11's
Mine was a SDPC pump/pick-up/pan take-off kit. The engine is a rebuilt ZZ3. So, it may be different than a factory fresh crate ZZ4.
It's a little higher than "usual" or "necessary", but not "too" high.
Car: 1986 IROC-Z
Transmission: TH350
Axle/Gears: 4:11's
Oh ok, Had me alittle worried there for a minute thinking my PSI was to low. always Been told that the psi was fine.
BTW. Sorry dident mean to hijack this thread.
Car: 83 Z28
Engine: 355
No worries on the jacking, I am trying to absorb all the info I can. This friday going to do an oil change and take a look at the oil pump. Can you buy a high volume pump locally usually or order them? If order, from where? Thanks.
ambainb
Apr 25, 2016 09:21 PM
