305 or 350? How can I tell?
Old Nov 14, 2009 | 12:54 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
How can I tell if my engine has been swapped for a 350 or if it still has a 305 in it?
Old Nov 14, 2009 | 01:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 305 or 350? How can I tell?
Since the only difference is bore size, the only way you can tell the difference is from a casting number. 305 and 350 blocks will never share the same block casting.
Old Nov 14, 2009 | 04:49 PM
TJ07RK's Avatar
Car: 1986 Camaro Z28
Engine: 305 Carb
I checked mine out just the other day. Looking at the engine from the front. On the left front by the bottom of the head there is a edge that sticks out and has some numbers on it. If some of the number match the last of your vin number it is the stock block. I had to claen the surface a little to see the stamped in numbers.
Old Nov 15, 2009 | 05:55 PM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
the block should say 5.7 or 5.0 liter on the top of the block towards the firewall..and yes another way to tell is the vin #
Old Nov 15, 2009 | 10:16 PM
breid16's Avatar
Car: 91 firebird
Engine: 305 tbi
Look on the drivers side, behind the cylinder head on the rear flange that bolts to the trans. bellhousing, that is the number you need to correctly id the block. I am also thinking that the 5.0, or 5.7 numbers are only on the new style blocks, post '86 i believe, center bolt valve covers. Hope this will help ya.
Old Nov 16, 2009 | 09:20 AM
SeanW's Avatar
Actually i am pretty sure they started the numbers on the block in 1980.
Old Nov 22, 2009 | 01:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I have only seen the 5.0 / 5.7 numbers on the 1 pce seal blocks which came out in '86
The 3 letters stamped on the block pad at front will identify
the model ,engine size, trans and year engine originally came with
Old Nov 22, 2009 | 01:34 PM
SeanW's Avatar
When i was in school for pre employment diesel tech i had to rebuild an 82 305, 2 piece rear main and it had 5.0 on the back drive side of the block behind the head. In fact there were two motors in class like that, donated by GM way back when. So i have seen a couple. Unless anyone has any actually proof otherwise i stand by my statement.
Old Nov 22, 2009 | 02:08 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
if you can only find a casting number or a suffix code here are two websites for that stuff
http://www.chevy-camaro.com/chevy-ca...es.asp?group=1
http://mortec.com/
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
