few more things to replace?
should i replace the fuel pump while doing this 305 to 350 swap? any thing else like distributor (just the coil and modual are new) or sending units or anyhting else....i have pretty much everything else
Transmission: 4L80E/4L80E
You never answered my question in your original post about your current configuration or the 350. Do you have a carb'd engine? If so, it should have a mechanical pump, and yes, now is the time to change if for a new one; won't cost much but it's a lot easier to change when everything's apart than it is later when it starts leaking on you or otherwise craps out. If you have an in-tank pump, you don't need to change anything.
Distributor will swap. If you have '86-later carb or EFI, you should get a 350 knock sensor & module, although you can probably live with the 305 piece.
sorry...its going to replace an 84 305 HO 4bbl....i got a 84 350 (brand New) 85' stock heads, crane cams energizer camshaft flat hydraulic tappet lifters, performer intake, edelbrock headers, new water pump, and i need to find a carb....any suggestions? (and on a tight budget)
Car: 88 Firebird WS6
Grab a v8 tank from a junkyard and usually you won't get smacked with the fuel pump price or take it out and hide it
You definatly need the connecting lines and have to upgrade to high pressure line.
You're also going to need the computer and wiring cause these cost $.
Other cheap options are to get the motor, get sensors out of a junkyard (pocket stuffers
) and a computer...
) and a computer...Supreme Member
Car: 1983 Z28
Engine: 6.6L 406
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
</font>
</font>
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Car: 1983 Z28
Engine: 6.6L 406
Sorry, i jumped from the first post down...
</font>
</font>
hope I didn't sound like a jerk. ------------------
future mods:
