anyone know anything about the 406?
Old Apr 24, 2001 | 10:35 PM
MouseCamaro305's Avatar
what is it? a bored 400? l think lve heard it been called a stroker too? anyone have any info?
thanks a lot guys
Old Apr 24, 2001 | 10:40 PM
BigBlockJason's Avatar
Car: 1985 Z28
Engine: 502
no, its not a stroker, its a 400 SBC bored out. A 434 or a 377 would be a stroker that started with a 400 block. Look here.
http://www.allchevyengines.com/406-435.htm
BigBlockJason
85 Z28 T-Tops
http://communities.msn.com/JasonsStuff/homepage
Old Apr 25, 2001 | 12:58 AM
offroader's Avatar
- A 406 is a 400 that's been .030" oversize. (4.155" bore x 3.75" stroke)
- A 377 is a 400 bored +.030" with a 350 crank. (4.155" bore x 3.48" stroke)
- A 434 is a bored and stroked 400. (4.155" bore x 4.00" stroke)
Old Apr 25, 2001 | 03:59 PM
thanks a lot guys l really appreciate it
Old Apr 26, 2001 | 04:22 PM
Tom Batts's Avatar
406/435HP
400 GM 2 bolt block
New Elgin "cast steel" 400 crank (std,std)
Stage 3 superstock 5.7 rods with ARP "wavelock" rod bolts
Hypereutectic flatop pistons (10.3:1 comp)
Sealed Power rings
Hydraulic flat tappet camshaft (.500 lift,292 duration)
Heavy duty Cloyes timing set
Michigan 77 bearings
High volume oil pump
Fel-Pro gaskets
World Products "Dart II Sportsman" heads
Hard seats and guides for unleaded or reg fuel
New 2.02" stainless intake valves
New 1.60" stainless exhaust valves
Screw in studs and guide plates
New Crane dual springs
New chrome moly pushrods
Crane roller rockers
New oil pan, timing cover and chrome valve covers
New GM harmonic balancer damper
New heavy duty flexplate (std trans flywheel extra)
Edelbrock Victor Jr manifold
Balanced, blueprinted, assembled and painted
only $3499
that's a GOOD DEAL
Old Apr 26, 2001 | 04:27 PM
FAST LiFE's Avatar
Anything in specific that you want to know about it?
N/A 406, TPIS Miniram, 58mm TB, 30lbs injectors, Custom Ground Elgin Cam, Ported TFS heads, SLP 1-3/4", & DFI computer.
11.70@117mph
Old Apr 26, 2001 | 09:54 PM
well..... nothing really in particular, l was just wondering what it was, me and my brother were actually looking at an 84 cutlass with a 406 in it, apparently the guy says it runs 11.70's on all motor in the 1/4 does this sound right to you guys with a 406?
Old Apr 27, 2001 | 12:56 AM
FAST LiFE's Avatar
Considering I run 11.70's @ 117mph and I know of a few others with 406's that have ran faster NA, I think it's very possible. You just have to throw together the right combination of parts.
11.70@117mph
Old Apr 27, 2001 | 10:37 AM
thanks a lot guys, l really appreciate the responses.
Old Apr 27, 2001 | 03:23 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
mine will run 11's with some tuning. i only had it to the track twice and didn't even know what jets i had in there until this winter.
like the last guy said, you just have to have the right combo. i love the way mine runs right now, so i don't plan on any more motor changes for a while. well, maybe some juice next year
unfortunately, the slicks i was using have been sold and i don't have any more cash to **** away on a set of new ones. i may run it just to see what it will do on my 18's.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
406 balanced with 6" Eagle H-beam rods, 10.25:1 JE SRP pistons, Comp 284XE cam; 240/246 @.050, .507/.510, Dart 200cc Ironeagle heads, Victor Jr. intake, Holley 750 vac sec.
12.20 @ 115.25 mph
Old Apr 27, 2001 | 09:43 PM
about the 406, like l said, lm not too familiar with the exact specs on the motor thats in the 84 cutlass, but what kinda pistons are you guys running with your 406's? you think it could be possible the guys got forged pistons and a nice forged crank? how much juice do you think it would take to propell it into high 10's how much juice do you think it could handle? being either forged or cast
thanks again guys
Old Apr 27, 2001 | 09:44 PM
sorry, l forgot to mention that me and my brother are actually looking at a 84 cutlass with a 406 carb in it, he claims it runs 11.7's in the 1/4 which l beleive is very possible from what l've been hearing.
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
