zz-4 Tunedport?
Old May 8, 2001 | 08:21 AM
DanW's Avatar
zz-4 Tunedport?
I have a 91 Trans-am and i swaped the stock 305 TPI for a 350 zz-4 Create motor, using the stock TPI Intake/TPI setup. All seemed to be working untill it flooded with Gas, the injectors are pumping too much fuel, where would the sensor be located? i have replaced the map sensor, the 02 sensor, replaced the computer, replaced the electronics in the distribuitor, and changed the coil. Anyone have any ideas?
Old May 8, 2001 | 03:29 PM
ImportEater's Avatar
Honestly, I'm not full of knowledge about all of the sensors involved with the ECM on your car. However I'm fairly certain when I say that you probably inadvertantly eliminated a necessary engine mounted sensor, like the timing sensor (?)
Check it out.
1985 Trans Am - rough and ready -- 3" cat and primary exhaust, lowered 2", custom rust body work mild fender denting. Daily driver.
1976 Corvette Stingray - not so rough, but always ready. mild 350/th350 tranny. mostly stock till I whack the hood for the blower
Old May 8, 2001 | 03:32 PM
DanW's Avatar
Humm, when we did the motor swap, i kept the stock wireing harness, and all the plugs pluged in, We did have to move some sensors from the 305 block to the 350 block, but there where mounting spots for the sensors. Also, i have a injector light (that you plug into the harness) and on my Dads TA they blink, on mine they stay light (and keep injecting fuel) Any ideas on that?
Tunedports1002
35
Apr 19, 2011 04:16 PM
Tunedports1002
Dec 2, 2008 07:35 PM
TunedPort 335
Aug 22, 2006 04:43 PM
Incoming
Oct 2, 2004 05:33 PM
mike graycar
Jul 8, 2003 12:08 AM
