305 tpi engine removal
Just bought a 1986 305 with a suspect knackerd bottom end for a good price.
The guy i bought it of has started to strip the motor for removel.
Any tips on how to remove from the car?
Will it come out from the top or have i got to remove from the bottom?
I really do not want to remove from the bottom because of having to undo the brakes etc. and i need to move the car straight away because space is very tight in my garage.
All tips would be welcome.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It can be removed from the top. That's the usual way of going about it.
Basically it's a matter of unbolting things from the engine, holding it up while you undo the mount and bellhousing bolts, then lifting it out.
The_Phoenix
Sep 3, 2015 10:56 PM
