79 Eng converting to TPI can it be done??
Old May 10, 2001 | 04:36 PM
EnTwisted_Iroc's Avatar
Can I take a 79 350. and take off the manifold off my 89 350 Tpi and have it all bolt up and work, If possible how will it run.
Old May 10, 2001 | 05:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not quite. The center 2 blot holes on the intake are at a different angle. However, if you use the 89 heads, it will work.
ICON Motorsports
Old May 11, 2001 | 01:42 PM
camaroguy99's Avatar
If you are thinking about putting the 79 block in the 89 it won't bolt in, 86 (or 88 can't remember) - up have one piece rear main seals and the earlyier ones have a 2 piece.
Old May 11, 2001 | 07:37 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i THINK it will if you use the 1979 flexplate
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
