crank hitting basepan?
Old May 12, 2001 | 03:37 PM
virtual's Avatar
i got motor put in my 83 z28 its 305 anyway when they put it in it was knocking buddy said engine was gone but another guy i know said could be crank hitting basepan becouse thats were the noise is coming from.can this happen?Please help?
Old May 12, 2001 | 05:55 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
More than likely it's either a rod bearing, or it threw a rod. Either way it needs to be rebuilt. The noise is sometimes so loud that it does sound like it's hitting the oil pan. (I assume that is what you mean when you say base pan?) Usually if you pull off the oil pan, you can look up there and see. Try to jiggle the rods to see if any do jiggle. If one does jiggle then it might even be a busted wristpin in a piston. I can't hear the noise from the engine, but from what you told so far, it don't sound good.
Old May 12, 2001 | 06:10 PM
snoozeyaloose85's Avatar
I had an 305 I thought was a rod bearing but it was indeed the crank hitting the oilpan. I confirmed this when it ***** a hole through. I must have dentted the pan when putting the motor in to fast and not taking my time
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
80smetalfan
Sep 22, 2015 02:55 PM
87camaro87
Sep 9, 2015 10:29 PM
