what do i have to replace????
Old May 13, 2001 | 08:29 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
there is a very good chance i am going to be doing a TPI 305 swap into my 3.1 5 speed in the near future
now besides the transmission, motor mounts, radiator, exhaust, and computer what else will i have to change???
in other words: what little things need to be changed??
Old May 13, 2001 | 01:32 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
<font face="Verdana, Arial" size="2">Originally posted by 1991tealRSt-topGuy:
</font>
Brake line from drivers side over to passenger front caliper, the cat and exhaust from there back can stay the same but the manifolds and y pipe need to be changed, you can still use the stock pump, some say you need to change the front springs, well why not just order a set of rear drop springs from jc whitney for like $80 and you get a drop kit in the swap , you will need the whole engine and acessories setup including power steering lines, think thats it.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
