305 and 350 harmonic Balancer?
Old May 15, 2001 | 12:32 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
Can I use my 86 305 harmonic balncer on my new 86 TPI 350 or are they different?
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old May 15, 2001 | 12:51 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
They are different, but i think you can have the crank or the balancer rebalanced for the 305 balancer. I am almost positive that you have to get a 350 balancer.
Old May 15, 2001 | 01:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 305 balancer will work on a 350, there are no balance issues. The crank is the same casting # (442 in most cases).
The 305 balancer however is lower mass, and therefore isn't as effective at damping vibrations as the 350 ones. Even though it fits and will "work", I would not recommend using the 305 one on a 350 although swapping them the other way is fine.
ICON Motorsports
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theshackle
Aug 22, 2015 06:52 PM
st.evel07
Aug 13, 2015 06:15 PM
