305 swap for 350, interchangables and good ideas are welcome
Old Nov 30, 2009 | 09:42 PM
yzarcem's Avatar
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
Been a long time, but it felt good to login! I have a 350 on an engine stand...and will be ready to swap soon. Details are a bit sketchy (it is used...kid wrecked the car and the engine had about 5,000 miles on it//dad demanded that the car be parted out. The cast number is GM20 3970010. The plate on the passenger/front is blank. There is a silver plate in the driver/rear side of the engine that has: 1322 994350 on it. The header stamp is G99 MEXICO. The intake manifold is 346250. It is topped with a Holley 80457 4bbl carburetor. Unknown—head type, HP, 4-bolt or 2-bolt.
I'm planning a swap soon. I plan to interchange the MSD ignition and possibly the intake manifold (350 stock changed for Edelbrock Performer 2101). I have to replace the valve covers on the 350 (one is dinged pretty bad). I'll probably dump the Q-Jet for the Holley, but the jury is out. The Q-Jet is simply too temperamental!
Here are my questions--
1. Changing the 350 intake manifold for the E-brock performer 2101...good idea, or not worth bothering with with?
2. I have about $250 that I could spend (hey...Christmas is coming fast) before pulling the 305, cleaning the bay, and putting the 350 in to enjoy it. What else would you do within the $250-$300 budget. This is a fun/recreation car, to work twice a week...no emission concerns, twice a year 300 mile driver; gas mileage doesn't scare me. Should I upgrade the cam since the valve covers are off anyway, or should I wait & match it to a better intake? Recommendations on that (What's the keyword here...mild?)?
3. Anybody have a great set of heads for sale within budget?
Thanks in advance, all. Everytime I start thinking, I wind up with a wishlist that involves tearing this thing apart, but I just can't do that right now. Again, it's fun to be back.
Old Nov 30, 2009 | 09:49 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 305 swap for 350, interchangables and good ideas are welcome
The valve covers are off, so what's the casting number on the heads?
Old Nov 30, 2009 | 10:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Your going to need a tv cable geometry corrector, and a new throttle cable mount to switch to the holley, and maybe fuel hose and/or adapters as well - so don't go blowing the $250 yet. You'll need the $250 plus some just to do the swap for little things like gaskets, etc.
The 2101 won't help or hurt much either way.
Old Dec 1, 2009 | 02:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
350 heads - my money is on 882, 624, or something similarly lame. You'd be better off with your 305 heads.
Carb - I'd take the q-jet over that Holley any day.
Cam upgrade - would be worthless without exhaust upgrades, and if the heads are what I suspect they are, wouldn't help much. With the 305 heads and exhaust upgrades, it might be worth it. But, with only $250 to spend, you aren't going to get a very good cam if you can't afford new valve springs, too.
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
86Base
Aug 8, 2015 01:34 PM
