Can I put '86 305 heads and TPI on a 383 Stroker?
Old May 27, 2001 | 09:41 PM
86Z28TPI's Avatar
I am going to buy or build a 383 stroker. I want to do this in steps. I'd like to be able to use the heads and TPI on the 383 until I can buy better heads. Can I use the '86 heads and the TPI on a 383? I built up the heads with Magnum roller tip rockers and lightweight valves a while ago so I'd like to keep them as long as I can (to save up some more $$$). What heads would you guys recommend for the 383? Thanks for all your help.
Old May 27, 2001 | 09:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can but you're not going to happy with them. 305 heads can't flow enough air to feed a 383.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 27, 2001 | 09:57 PM
86Z28TPI's Avatar
Thats what i figured about the heads. Any suggestions for what heads to use? I will also need a new PROM chip right?
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
st.evel07
Aug 13, 2015 06:15 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
drathaar907
Aug 6, 2015 04:20 PM
