Bad news so finally giving in 383 time
Old Dec 9, 2009 | 09:00 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
After honeing my block to day i found a bad clynder wall so i figured that if i am going to build a motor i am going to do it right.
so i put the 355 motor back in the shop and pulled out the 350 010 block 4 bolt main. i have a eagle forged crank 3.75 stroke and i am going to use the powered metal rods with arp bolts unless i find a diffrent set.
My father gave me a set of 64cc heads with manley stainless valves 2.02/1.60 and ill get the numbers later
I found a set of .30 over trw forged pistons for a 100$ but the block i have is already .30 over so i might go .40 over.
Old Dec 9, 2009 | 09:19 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: Bad news so finally giving in 383 time
piston number is L2491
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
