I'm having wiring issues...
Old May 11, 2001 | 01:37 PM
camaroguy99's Avatar
Alright I'm in the middle of swapping in a 350 SD TPI for my 305 TBI and I've noticed a few problems with the wiring. First the windshield wire motor is connected to the engine harness on the TBI engine on the TPI harness it appears to me comming out of the left side of the huge 2 piece connector that goes intot eh drivers side firewall. Has anyone had to deal wth this issue?
Second, with that large black connector, the pins on the TPI harness' connector don't match up with it's receptical in the firewall. Will this be a problem? Any advice would be great. Thanx
Old May 12, 2001 | 02:12 PM
RSroller's Avatar
I am in the middle of changing my 2.8L into a 350. I have come across that same issue plus more with mine. but I'm just going to get a painless wiring harness. let me know what you do to your camaro.
Rjbartson@yahoo.com
Old May 16, 2001 | 11:58 PM
442guy's Avatar
the large black connecter is the fuse block connector. i guess you are trying to use the v8 engine harness with the tbi interior harness? this is an annoying task but it can be done. use the engine side plug from the original motor, cut it off the original harness with about 6 inches of wire on it. then cut off the new harnesses connector, and butt connector the old plug onto the new harness red to red, purple to purple etc. count the wires and colors befor you do it to make sure there are the same. if there are a few small ones like a brown or a green left over, those are either ac power, or guage senders. the passenger side, youll have to find out what colors are suppoesed to go in what pin number(location)on the plug which connects the engine,computer, and dash harnesses, then move around the tbi wires to the right spot for the tpi,
Old May 17, 2001 | 06:33 PM
thats worth a shot thanks. Now does anyone have any info about the windshield wiper motor?
Old May 24, 2001 | 07:38 PM
ttt
Old May 25, 2001 | 07:50 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Get a service manual. It's invaluable.
Old May 25, 2001 | 01:08 PM
I have one but it doesn't help here. It's the fact that the wiring for the windshield wiper motor is on different parts of the harness in 88 and 91 and I was wondering if anyone had delt with that kind of issue?
Old May 31, 2001 | 05:40 PM
I'm sure some one has had this problem. Please help!!! Thanx
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
