350 with Procharger
Old Dec 14, 2009 | 12:52 PM
MMMichael's Avatar
350 with Procharger
I am thinking of swapping a 350 sbc with a procharger supercharger into a 89 RS camaro. I'm wondering what all i will need to do to the following things
-Suspension Mods.?
-Engine work, as in what types of internals should be involved in a supercharged motor.
-Rear end and drivetrain. (Rear, Driveshaft, and tranny- I'm thinking a 5 or 6 speed manual) Car is an automatic originally.
Any help or advice on the topics will be appreciated. I am no stranger to motors or fabrication to the car so i can do all of the work myself. thanks!!
-Michael
Old Dec 14, 2009 | 02:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by MMMichael
-Suspension Mods.?
Depends upon what you've already done to the suspension, and how much power you end up making.
That's really a topic for the Power Adder forum.
Again, depends upon the power you end up making. And, what you do with the car. At a minimum, you need to max out the stock 10-bolt (aftermarket carrier, gears, and axles; aluminum support cover; welded tubes). Most likely, an aftermarket rear like an f-body 9-inch or 12-bolt would be the best money spent.
Old Dec 28, 2009 | 01:28 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: 350 with Procharger
It all depends on your power output... a stock 350 will take 8-10psi safely ive seen them take more but a bright candle only burns so long
is it staying fi? or are you going carb?
main deal with a boost is that its addicting you can never stop you will always find yourself wanting more.
so i say forged motor arp bolts mls head gaskets all the work you are willing to throw at the motor it will be worth it.
suspension all depends on what ur plans are for the car?
rear end- i blew up mine with 600hp on a burn out..
axleshafts first then a posi unit or locker gears last
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
