Putting TPI on a ZZ4
I have and 86 Iroc. I also have a zz4 crate motor in another car right now but Im wanting to swap into the Z. What will I need to do to make this run right as far as different injectors and what not. Any info on this would be helpful. Thanks
You will need a new water pump (reverse flow), swap the distributor gear from the ZZ4 on to the TPI distributor, the stock TPI will kill the power that the ZZ4 makes, get a high flow base and runners and port out the upper (or get a miniram (tpis) of supperram (Lingenfelter)) and get a bigger t-body and injectors. I am using a 58mm t-body but a 52mm is just fine. Also I think cost for power the best injectors are the 24# svo injectors but there are allot of other options.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Ive got a budddy whos got some 24# injectors and a T-body. How do you think it would run if i put those on and just ported the upper intake and ran that for awhile until i could afford the runners and base. Also i was wondering where you got the chip for your car.
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by 91-ZZ4-Z28:
You will need a new water pump (reverse flow)</font>
You can plumb exhaust to the EGR 'Vette style.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
[This message has been edited by five7kid (edited June 11, 2001).]
Yes I did mean to say reverse rotating, and yes you can plumb it for the vette egr but its a waste of time and power if you turn it off in the prom an leave it in place on the manifold it will still pass emissions tests easily.
Iroc8t8
May 4, 2026 08:09 PM
Sanjay
Aug 12, 2015 03:41 PM
