454, should I get it.
Hey ya'll, I think I have a chance to get a a 454 that is built pretty stout(don't know exactly what is in it yet) for about $2000. Would this be a wise choice, and would the 700r4 last very long if I went easy on it. Let me know what you think.
Pics of my Car
http://albums.photopoint.com/j/View?...781&p=39417549
http://albums.photopoint.com/j/View?...781&p=39417539
http://albums.photopoint.com/j/View?...781&p=29492902
http://albums.photopoint.com/j/View?...781&p=29492901
305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
Pics of my Car
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I think that your tranny would be the least of your problems. It will hold up a whole lot better with a performance rebuild though. Your rear will not take it though.. WAY too much torque. The u-joints will be the next thing to give. You will have serious traction problems. It would be an awsome install though!!
- 89 Formula 305 WS6
SFC's, LCA's, Air Foil
Spohn Panhard Bar
Flowmaster Cat Back, Tranny Cooler
A/F Ratio Meter (not a mod but it sure spurs interest)
Trans Temp Gauge
Most "Free" Mods
3:73, Zexel Torsion Posi - 90 Eagle Talon 2.0
(Winter Beater)
Mods? Um, no
I think Omega got it backwards.
Your tranny will last for awhile if you take it easy. The preformance rebuild is a very smart idea though. The 700R4 can be rebuilt to take whatever that engine is going to dish out, even 600 hp. IIRC you have a 92 camaro, those have the stronger axles. It won't last forever if your hard on it but, it will live happily behind a 454 with a smart driver. If the U-joints are in good shape they won't give any problems either. If it was me... I'd change them during the swap just to be sure. Then all you have to do is keep a good maintanince(sp?)schedule.
Is it a 2 bolt or 4 bolt main? How old it the rebuild? Do you know any of the parts used in the rebuild? 2K for good 454 is good deal 2K for a nasty old truck motor with cheap parts is not.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Go for the 454 if it is in good condition. You will love the Torque!
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc,234dur.488lift exh&int,Victor Jr. intake, 770 Holley Avenger vac.sec 400 crank,flat top pistons,tranny shift kit,2500 stall converter. 3.42 ,Hooker Headers,2.5inchpipes with 40 s. Flowmasters,MSD coil,MSD module.
383 86 Camaro Z28
