305HO to 383 stroker?
Old Jun 20, 2001 | 07:09 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
ok im thinkin bout buildin up a 383 stroker for my car.....do you guys have any advice for me....like parts or things i may run into when im swapping them......would it b possible if i could make it so the computer doesnt control the 383??
and also how much hp and torque do you think i would have to b able to keep up or beat a 4th gen with a LT1??
cuz i saw a combo where it would make 367hp and 414torque.....how fast would that b??
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
Old Jun 20, 2001 | 10:38 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I did this exact swap you're talking about. I would highly recommend it. You will need ofcoars a different block(350)and some work at the machine shop, a 400 crank, pistons, and don't forget the starter. I have not been to the track but I have beaten quite a few 4th gen Z28's. Note: I have aluminum heads on my setup but you can go with some good performance iron heads instead.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc,234dur.488lift exh&int,Victor Jr. intake, 770 Holley Avenger vac.sec 400 crank,flat top pistons,tranny shift kit,2500 stall converter. 3.42 ,Hooker Headers,2.5inchpipes with 40 s. Flowmasters,MSD coil,MSD module.
Old Jun 20, 2001 | 10:45 PM
Car: 86 z28
I forgot about the computer question. I did away with my puter. You will need a different distributor,a different intake or you could use an adapter plate and since you wont have a computer anymore you will need a certain kit(switch) for your lockup converter(I went with a non lockup converter-2500 stall),I also removed the smog pump. My sig states almost all mods done to my car.
Old Jun 21, 2001 | 04:19 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
hey would you suggest that i got heads with the angled or straight spark plug slots?
which would b better with headers and stuff like that?
and what kinda heads would you suggest i get....i dont wanna spend a lot on heads..but i still want performance
thanks for all the help
Old Jun 21, 2001 | 04:23 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
oh
and did you do anything to your tranny or rear end b4 you did the swap.....or does your stock tranny hold up just fine?
Old Jun 21, 2001 | 06:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Read the articles in the magazine section by Steve Green ("Stroke in the Desert" or something like that). He did a 383 swap and kept the computer. He replaced the tranny with a built unit and put 3.73's in it. No 1/4 mile times, but he indicated it was fast.
I'd strongly suggest subframe connectors if you don't already have them.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 21, 2001 | 11:38 PM
Car: 86 z28
On my heads I went with angle plugs and I have no trouble with burnt plug wires. Now if you don't mind using a 5/8 wrench when taking off your plugs then you can go with angle plugs. As far as heads It really depends on what you can afford. Not saying you can't afford aluminum but you can also get some Dart Iron Eagles for slightly less(about 850.00 assembled). Kind of feel like I'm spending your money here . The reason I went without a puter is cuz I did some research and most of the input I got as far as computer was that it would not support more than 250 hp. Now I could be wrong with this figure but I just decided that a Holley carb(My favorite) would feed my engine what it needed. Up to this point I have not had a problem with my Holley . I have been able to tune it to the point my car feels unstoppable. As far as my tranny the only thing done to it was a shift kit and I'm running a 2500 stall converter. Although I have got another 700r4 beefed up in case this one goes south. You can run your current tranny then save up for a quality build up. Mine cost around 1200.00 . I would also suggest you look into this a bit more before you make a decision and post when you do.
383 86 Camaro Z28
Old Jun 21, 2001 | 11:45 PM
Car: 86 z28
Also I want to point out that if you look around you might find some quality heads that are less expensive than the Dart Iron Eagles.
Old Jun 24, 2001 | 09:08 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
alright
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
