power steering question??
Old Dec 26, 2009 | 11:14 PM
1bad71's Avatar
Car: 91 camaro z28
Transmission: turbo 400
Axle/Gears: 9/bolt
i am switching my 91 from a serp belt setup to v-belt.
my question is, is the ps pump the same pump for all the years (except the pulley and brackets of course)
what i'm trying to see is if i can just pull the bracket and pulley, and install the old style bracket and v-pulley onto the pump on my 91? or is there a difference in mouting hole/clocking of the pump?
it looks the same as my earlier pumps, but i don't have the brackets yet to tell if it will work?
any info from someone that has done or tried this would be appreciated. thxs jeff
Old Dec 30, 2009 | 10:15 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: power steering question??
I'm not exactly sure, but I believe it should work if you swap the pulley. I haven't heard of differences between ps pumps in thirdgens...
Old Dec 31, 2009 | 07:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There is a slight difference in the brackets, which makes the fillertop in the ps pump face the pass side instead of facing the driver side - but the pump is the same - just have to use a puller and get the old pulley off and press on a new pulley.
I swapped the serp brackets in my 1992 over to the 1/2 serp 1/2 vbelt setup, and I love it! No more big fugly brackets! I used stock ps bracket from 87 IROC, and an old school chrome alternator bracket since I swapped the alternator to the pass side (I removed smog and A/C).
However - if swapping from the serp, you will need a new water pump! The serp water pump is reverse rotation, and the vbelt is standard rotation. Also, if you want to move alternator to pass side, you;ll need the alternator from a v-belt car as well - the driver side mounted alternator (serp) has mounting tabs at 12 oclock and 4 oclock, the pass side mounted alternator (vbelt) has mounting tabs at 12 oclock and 6 oclock which is needed.
You an get somewhat an idea by looking at my first post here:
https://www.thirdgen.org/forums/auto...er-hood-2.html
Old Jan 1, 2010 | 11:32 AM
1bad71's Avatar
Car: 91 camaro z28
Axle/Gears: 9/bolt
cool! i already switched out the waterpump and alt, but wasn't 100% on the ps pump.
i had heard from someone that it wouldn't work! but from looking at it, it looked like it just needed the old school brackets. this saves me some $.
hey newbie! are you running the factory in tank fuel pump (fuel injected) to the regulator and then dropping it down for the carb?
Old Jan 1, 2010 | 04:16 PM
Car: 1992 RS
Engine: Carbed 350
Yep - intank TBI pump with Mallory 4309 regulator.
Old Jan 1, 2010 | 09:10 PM
1bad71's Avatar
Car: 91 camaro z28
Axle/Gears: 9/bolt
was going to do the same thing, but i have the tpi pump. and trying to drop fron 45 psi to 6 psi, likes to kill regulators!
ended up sumping the tank and running a complete fuel system.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
