305 ideas
Old Dec 27, 2009 | 12:16 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
305 ideas
Hi was wanting some insight on my 89 formula. It has a 305, iv recently been looking around for build idea's. I want to make it have some kind of power and torque but nothing crazy. Once im out of college i plan on it being my everyday driver (for the most part) but i want to be able to have some fun in it. Any ways i am wanting to rebuild once i get back but i dnt want all stock... just asking what any1 has to say so much as what you would do or what to do to it.. many thanks and i am planning on carbed or Tuned port injection
Old Dec 27, 2009 | 01:21 PM
chesterfield's Avatar
Car: Pontiac
Re: 305 ideas
Originally Posted by cypris09
... i am wanting to rebuild ... just asking what any1 has to say...
Is there a reason to rebuild it? Is it broke? Worn out? I say if the engine is OK then just spend your money on headers and exhaust. If that doesn't do it for you then heads and cam upgrade. But don't touch the shortblock if you don't need to. (And if you do need to rebuild it, don't. Get a 350. You can thank me later.)
Old Dec 27, 2009 | 02:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 ideas
Best seat of the pants to "feel" some fun for the 305 is rear gears - hunt down a posi rear with a 3.08 gear or better. Also as mentioned, exhaust will help. Doing much more than exhaust and LT1 cam and you're looking at chip programming to keep it running, as the stock ECM just gets confused with too many mods and actually makes it run worse (if at all).
Old Dec 27, 2009 | 03:51 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: 305 ideas
I took the ecm out it was for the most part junk... and yes the motor is worn and i have a posi with 3.43 or 3.42 also with disc breaks was just wondering cuz i can get a good quality rebuild kit from my brother just the whole 305 build between people is crazy.. i just want a dependable motor that sounds healthy and will put out when i want it to. doesnt have to put up big numbers i have a 79 trans am for that
Old Dec 29, 2009 | 11:39 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: 305 ideas
Anyone else have any more ideas? would appreciate some more insight
Old Dec 29, 2009 | 08:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I took the ecm out it ...
How did you go about that?
Old Dec 30, 2009 | 05:17 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: 305 ideas
I Swapped in a holley carb and a new intake.. also swapped in a new hei distributor so ecm might run my fuel pump and thats about it..
Old Dec 31, 2009 | 10:24 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: 305 ideas
3.42 gears
LS1 aluminium driveshaft
Headers (NOT Edelbock)
cat back (Magnaflow)
ZZ4 Cam
chromemoly pushrods (Comp)
Full roller rocker (Comp)
Trick flow 305 heads
2400 stall
Have fun.....................
Old Jan 1, 2010 | 12:13 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: 305 ideas
Now thanks that is a bunch of help and good ideabut i am also looking for for guys and thanks to all who have mentioned anything so far
Old Jan 2, 2010 | 06:17 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: 305 ideas
im not sure id even touch the 305.
do exhaust, headers, cat back, cat delete (if wanted). and trans work converter, shift kit, etc. pretty much things that just set up a good basis for and engine swap. im not knocking a 305 build but its my experience that everybody likes to keep going faster and faster
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
Derick15
Sep 17, 2016 05:28 PM
GouldyGTR
Aug 21, 2015 10:43 PM
