Vortec or L98 Vette heads on a 350
Old Jun 27, 2001 | 12:35 PM
Z28Man's Avatar
Besides weight, which heads are better? I have read that Vortec heads flow great, but Vette heads will increase compresion ratio to near 10:1. Which I believe is fine with AL heads. What do you guys think??? Thanks
Old Jun 27, 2001 | 01:22 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
if your not running a tuned port set up... Go with the Vortec's. They are a much better head.
If i remember the vortecs and the vette heads share the same 63cc combustion chamber so the compression ratio will be the same. with the compression ratio the same the vortecs will produce more power than the aluminum vette heads, by a sizeable amount more than likely
The drawbacks to the vortecs, must get a vortec intake, and the wieght, and with eitehr head you will need to replace the vavle springs.
The vortecs should not ping at 10.0 to one on pump gas,
Old Jun 27, 2001 | 02:49 PM
Z28Man's Avatar
The Vette heads are 58CCs and I am using the stock 88 TPI.
Old Jun 29, 2001 | 10:43 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
vortecs are 63/64cc, and the aluminum vettes are 58 cc, at least some of them. FYI.
The big cluster**** is getting tpi on vortec heads. Still no easy way to do it until Scoggen dickey finishes their intake!
Old Jul 1, 2001 | 10:09 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Yeah, I'm waiting for that intake, too.
Vortec heads share the same intake port design as the aluminum LT1 'Vette heads, which is why they flow well. I have a ported set I can't wait to use. But due to the raised ports and different bolt angle to the intake, different number of bolts and the new 'reusable' intake gaskets, you need either a SD- Vortec TPI intake or a modified stock TPI intake base. I have no info on that, does anybody know or has anybody modified a factory-style TPI base to fit Vortec heads? I'm interested, too!
The aluminum 'Vette heads are 58 cc's, Vortec's are rated at 64, although many cc at 61-62cc's.
MustangBeater20
Oct 29, 2022 09:20 PM
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86White_T/A305
Aug 17, 2015 12:16 AM
